It is currently Thu Jun 19, 2025 1:54 pm
PostPosted: Wed Jan 11, 2006 7:43 am
What's a good source for wood purfling strips of many different woods? I'm not talking about the widely available black/white fiber stuff or herringbone or any of that, just plain wood in varying thicknesses. If the same supplier has a really wide variety of wood bindings as well, all the better. I'm aware of Gurian, but I don't know if I'm going to order enough for their minimum order (although maybe a group buy wouldn't be a bad idea).
Thanks!
Todd Rose
Ithaca, NY
PostPosted: Wed Jan 11, 2006 7:50 am
LMI has a prety good selection from ebony to mad rose as does Allied. I know BobC has a good selection of bindings as does Steve at Colonial. Purfling in anything but maple is hard to find
PostPosted: Wed Jan 11, 2006 8:02 am
If you don't mind larger batches and a 200 dollar minimum order, Gurian Instruments is kinda hard to beat. Lots of species, colours, and options, and a nifty applet for building your own binding/purfling.
If you want something special but don't want to buy an entire layup's worth, per se (ie, 40 pieces or more), BobC and LMI are good bets.
PostPosted: Wed Jan 11, 2006 8:11 am
Try this place
THIS PLACE
PostPosted: Wed Jan 11, 2006 8:28 am
Dover
PostPosted: Wed Jan 11, 2006 9:18 am
You might try veneer supply businesses. Try www.wood-veneers.com or www.veneersupplies.com. Their web sites are a little awkward to navigate, but you can get individual sheets or flitch-matched lots of some beautiful veneers for a small outlay of cash, and cut your own lines.
PostPosted: Wed Jan 11, 2006 10:39 am
Todd,
I have some Gurian stuf and order from them every once in a while. I have a crappy picture of what I Have in stock on the pricing page on my website. I could be convinced to order what you need from Gurian and couple it with some other stuff I could stock.
PostPosted: Wed Jan 11, 2006 10:44 am
[QUOTE=CarltonM] You might try veneer supply businesses. Try www.wood-veneers.com or www.veneersupplies.com. Their web sites are a little awkward to navigate, but you can get individual sheets or flitch-matched lots of some beautiful veneers for a small outlay of cash, and cut your own lines.[/QUOTE]
And a quick way to cut your own lines is to use a pasta maker -- ya know, the one with a hand crank and the rollers.
Best,
Michael
Live to Play, Play to Live
PostPosted: Wed Jan 11, 2006 11:28 am
[QUOTE=Michael McBroom] [QUOTE=CarltonM] You might try veneer supply businesses. Try www.wood-veneers.com or www.veneersupplies.com. Their web sites are a little awkward to navigate, but you can get individual sheets or flitch-matched lots of some beautiful veneers for a small outlay of cash, and cut your own lines.[/QUOTE]
Best,
Michael
Huh. Never would've thought of that. That only goes for single, thin veneer stock, I take it? I've got an old one we never use, my late grandmothers, 50's Italian workmanship. Intruiging...
PostPosted: Wed Jan 11, 2006 12:58 pm
First name: Josh
Last Name: French
City: Houston
I use veneers. But I'm itching for some of Bob C's snakwood purfling!
Instagram: @jfrenchluthier
PostPosted: Wed Jan 11, 2006 2:45 pm
OK, I'm going to reveal one of my secret weapons. Many years ago I bought
a 30" paper cutter from a bulletin board ad (this was before the internet, if
you kids can imagine such a time). It does a great job of cutting purfling
strips from veneer sheets.
PostPosted: Wed Jan 11, 2006 3:31 pm
[QUOTE=Mattia Valente] [QUOTE=Michael McBroom] [QUOTE=CarltonM] You might try veneer supply businesses. Try www.wood-veneers.com or www.veneersupplies.com. Their web sites are a little awkward to navigate, but you can get individual sheets or flitch-matched lots of some beautiful veneers for a small outlay of cash, and cut your own lines.[/QUOTE]
Best,
Michael
Huh. Never would've thought of that. That only goes for single, thin veneer stock, I take it? I've got an old one we never use, my late grandmothers, 50's Italian workmanship. Intruiging...[/QUOTE]
My pasta cutter (made in Italy -- we bought it over 10 years ago and used it once) has two cutters. Think linguini and fettuccini. The linguini cutter is perfect for side purfling (and for the top and back if you stairstep your binding/purfling channels) and the fettuccini cutter works well for wider pieces.
I either cut veneers into pieces about 5" wide or buy them from LMI (which are about that width), then feed them into the pasta maker. So far, I've cut curly maple and EIR. Grant Goltz, whom I picked up this trick from, has used it on several different kinds of wood. I find it works best if the veneer is wiped down with a damp cloth or paper towel first. Less splintering and breakage that way. The only trick is to keep the veneer sheet feeding straight. It will try to feed itself in at an angle if you don't watch it.
Best,
Michael
PostPosted: Thu Jan 12, 2006 1:04 am
Please Michael, if u can, i'd really love pictures of the process!
PostPosted: Thu Jan 12, 2006 2:02 am
Serge,
I haven't taken any pictures of my cutting purfling strips with a pasta cutter, but Grant Goltz has taken some. I "borrowed" a photo of his from the other forum, and will post it below. Man, I sure hope I don't get in trouble for this. I hope Grant doesn't mind.
He mentions in his post that it's important to keep the veneer damp. The wood in the photo is bloodwood.
Best,
Michael
PostPosted: Thu Jan 12, 2006 2:58 am
No problem, Michael. Actually you just beat me to it    How well this works depends on the veneer. The straightest grained stuff obviously works best. The thinner (1/40") veneers work the best. Make sure the wood is damp for the easiest cutting and least breakage. This is better a two person process, one cranking, one guiding the wood. Half of the strips will go straight down and half will pass through the open bottom of the cutter (you can see this on the photo). Don't expect to get all good strips, typically half will break, but can be used for soundholes, pegheads, etc.
As Michael noted, I have cut many varieties of wood this way. I have even sanded straight grained ebony down to veneer thickness and cut that. Tightly curled maple cuts quite nicely. There are some woods that are just too brittle, but you can't predict what will work. Just need to try it. The only thing is that cutting for one guitar gives piles of "extras"
Hope this helps.
Grant
PostPosted: Thu Jan 12, 2006 3:23 am
There's a pretty good article in the latest issue of American Lutherie that describes a couple of different ways to cut your own strips as well. Can't remember the author's name for sure, but it might be Greg Byers.
PostPosted: Thu Jan 12, 2006 5:27 am
Thanks for your help bros, sure was great !
PostPosted: Thu Jan 12, 2006 6:17 am
Thanks, everyone, for your replies. I'll look into the two sources suggested by Lance and Steve, and also take a closer look at Gurian.
Shane, if I'm thinking I'd like to get stuff from Gurian, but I'm not putting together an order that's approaching their minimum, I'll get in touch with you.
Thanks also for the suggestions for making my own strips from veneer. I'll probably try that sometime, but if I can find what I'm looking for ready-made from a supplier, I think I'll do that for now.
Todd Rose
Ithaca, NY
PostPosted: Thu Jan 12, 2006 10:45 am
Ready to ship pasta cutters to OLFers worldwide
Gg
PostPosted: Sat Jan 14, 2006 3:25 pm
Hmm, wonder how the pasta attachment for my wifes kitchenaid mixer would work? Wonder if my wife would kill me?
PostPosted: Sat Jan 14, 2006 5:23 pm
No problem Todd, just let me know and we will get something going. I just hope you find what you need.
